What are some good FREE mods??
I dont know if these are good tips or not, but here goes. Take out the air filter completely and I think that will help some. The mass air meter Im assuming on the L's has a screen in it, so that will atleast stop some big particles from entering the engine. Less air in the back tires for better launch helps some, as does more air in front tires for less rolling resistance. Taking out the air filter does help, but Im not saying you should drive around like that, you can do it at the track when you run, then put it back in for the ride home. Mike
Originally posted by SLP 97 CAMARO SS GUY
I dont know if these are good tips or not, but here goes. Take out the air filter completely and I think that will help some. The mass air meter Im assuming on the L's has a screen in it, so that will atleast stop some big particles from entering the engine. Taking out the air filter does help, but Im not saying you should drive around like that, you can do it at the track when you run, then put it back in for the ride home. Mike
Doug
Re: Easy Mod
Originally posted by Johnny AC
Remove your drivers side headlight. It's easy and will let more fresh air get into your engine compartment near the air filter. I can't take credit for this, SouthJersey Fred showed me and it helps, John H.
Only makes the truck look stupid, LMAO, that was a good one, and true too. One eyed L would look odd as would any car I bet. I think what hes saying to do would help if you had a different intake set up with dryer hose or something going to the missing headlight area like they used to do in the 5.0 days. Mike
