A/F ratio and timing
Got my truck back from the dealer last night so i put all my mods back on. I called my tuner to ask what my a/f and timing was on my chip. He said 11.8a/f on both sides and 11cold-14hot on street side timing and 16cold -18.5hot. How do these numbers sound for a 2 or 4 pound pulley?I might have the hot and cold numbers backwards if so correct me.
Re: A/F ratio and timing
Im 30-45 minutes from birmingham depends on if im the L or the ranger.Ill check the dynojet site to get some numbers to call.
http://www.dynojet.com/maps/autodynos/al.htm
Dan
If you go to Mobile call Pete at 251-476-4445, he is a really nice guy and will set you up on the dyno. He does a lot of L pulls with me and can give you your graph with HP and A/F. Needforspeed is right, there is no way anyone can tell you what your numbers are, just what they should be with past experience on programs but all L are a little different. Or you can get with me and use our FJO and check it on the road, Im also in Mobile.
