rough idle?
I d/k why a full gas tank makes a difference but a loping idle or an erratic idle can be caused by:
1. Vacuum leak(s) Check by listening with a stethoscope--if it will idle.
2. Leaking EGR valve or a plugged PCV valve.
3. Air filter clogged.
4. Fuel pump not delivering sufficient fuel.
5. The other reasons are because of an internal eng. problem, leaking head gasket(s), timing chains worn, burned valves,
Also could be ignition or PCM related?
Dan
Dan
Originally posted by Coldie
It's weird... It doesn't really lope, just occational it misses.
Coldie
Coldie
1.. Faulty s/plugs or not gapped properly.
2. Wet or 'bad' coils.
3. Sticking or faulty emissions systems.
4. Clogged fuel filter(you recently changed it) or foreign matter in fuel.
5. Vacuum leaks.
Dan
