Did I blow a plug? How can I tell?
I was driving at about 45mph and 30-40% throttle. At the 2-3 shift the truck shifted really hard and felt like it missed a gear. I didnt hear any particularly unusual sounds aside from a loud shift. The boost dumped and the temp gauge pegged at Hot. The SES light came on and I pulled over. I dont see a fluid leak and so I restarted the truck. At this point, it restarts OK and runs fine. The idle *might* be a little rough but It wasnt exactly silky before. Truck seems to run OK, but the SES light is still on.
Short of dropping my truck at the dealer for a week, how do I know if/what went wrong?
Chip is still firmly seated and the truck isnt making any odd sounds. I dont see anything that looks like an ejected coil pack or plug, but I havent taken the coil packs off to check.
yes, I restarted the truck with the hood open. Everything *looks* OK. the temp gauge is now acting normally. There's a slight and random miss if you listen by the exhaust pipe, but that's not really new either.
The odometer diagnostic thingy registers the following:
idle 750-800rpm
fuel 182
dt 649F
dtc 9202 (fuel sender open circuit?)
dtcd 262
dtcd 073
idle 750-800rpm
fuel 182
dt 649F
dtcd 262
dtcd 073
With your symptoms, it sounds like something has cuased your truck to go into limp mode. When that happens, you'll get a SES, and the trans will default to full line pressure and not all gears will work. Since your temp gauge pegged, I'd guess that the truck overheated for some reason, which set the failure mode. Our trucks have a unique overheat failure mode that will allow the truck to still run, but will kill cylinders to help keep the motor cooler.
Like it's been said, if the plug blew you'd know cause there would be an ignition coil displaced and a hole where one of the plugs were.
In addition to Sal's advice I would carefully retorque (not overtorque) all the plugs.
Maybe I should market a CANBUS networked 'Strain Gauge" insert for all the plugs to warn when one is coming loose..... Or you can buy the 8 threaders
code read
the only other time i saw a temp guage go from normal to pegged is with a bad head gasket, was the truck at normal temp then just go to full??
Doug, I went to autozone as you suggested and they read the code but said it was a manufacturer specific code so they couldnt diagnose it. Anybody know what P1227 or P1299 means?
