Noisy Belts (squeal at shifts)
I just installed a new Gator Back SC belt... because it squealed at WOT shifts with the stock belt. It still does it and now as low as 1/2 throtle now, since I just did the Factory Tech Valve Body . So I guess my squeal at shifts is the accessory belt (I did know that it could be either belt). Just wishfull thinking it was the easy belt to change! Not looking forward to changing that accessory belt.. rumor is a pulley has to be removed to do it
Also my new SC Gator Back Belt has a loud constant whriling whistling sound. Will this go away as it wears in, should I wait or should I go back to stock???
