to reburn or not to reburn
Running an 01 L with glasspacks,honed and polished TB and upper plenum, airforce one filter, and a superchip with their off the shelf program(R9N5 I think). If I add a 2 lb. upper pulley, do I need a reburn on my chip. I called the guy I got the chip from and he said I need to get a dyno run and see what the A/F is. Also do I need a smaller belt or would the tensioner take up the slack? I have'nt installed the chip yet, and my tips seem to be pretty black all the time.
Belt should be fine with 2lb pulley........dyno with A/F is your best tool for determining if you need a reburn or not. If you don't have the chip in, i would get it in there and get the dyno done and see how it looks, use that to determine if you need a reburn. All the other mods shouldn't matter to the chip. And even if the A/F's are good I bet one of the tuners can give you a better program than the superchips one. Good luck
