changed my oil and spilled some ??
I was changing my oil tonight and accidentlly spilt some near the filler and got some on the motor. and also i came up a little short. i think these trucks like 7qts instead of 6. After i started it seems to be idling louder. almost like a lose vacuum line, but i checked it and the are fine? its only at idle making that well known diesaly sound. any ideas if i spilt the oil on something im not suppose to? i whiped as much of it as i can up.
oh yeah. how much does our stock trans pan hold? i moved and my manual is packed up somewhere.
The factory fill is 6 qts of motor oil but some guys put in only 5.5 qts. to reduce the unwanted oil in the intake. You are fine as long as the oil level is above the 'add' or 'min' mark. Good advice and the only way to get an accurate reading; "check when cold(I wait until morning/overnight) and on level ground".
Dan
Dan
