Who can diagnose my truck problem?
On the way to work today I was sitting at a light and my RPM's dropped to zero and the truck almost stalled. It has never done this and it was on my conservative driving program. Could this be from a lean condition? the truck has never done this before and hasn't done it since.
Kinda stumped as to what it is. Check the sig for my mods....
Thanks guys,
Griffin
Thanks guys,
Griffin
It's your IAC valve. They get dirty/carboned-up and this allows too much air in when at idle rpm. Here is some more info:
https://www.f150online.com/forums/sh...cleaning+valve
Take it off and flush/soak it out with any solvent--reuse the old gasket. If cleaning it doesn't fix it then you'll have to replace it--about $50 at Ford.
Dan
Dan
Dan
Dan
most likely this is the issue, have 13K on my truck and its happened twice. Either that or its a simple issue such as a fuel filter etc,,, i doubt it though, most likely the iac valve.
~Toast
Originally posted by Griffin 01 L
WHAT IS THIS IAC VALVE YOU SPEAK OF!!!!!
HTH
