Which chip?? Any new thoughts?
I know this subject comes up from time to time, but. . . . .
What chip set up do you recommend for a stock 2002 L?
Is just a chip good enough for a noticeable improvement?
Who has done just a chip and what kind of difference did you get?
Thanks for any comments.
Yes, just a chip will give you a 'rush'. Your shifts will be firmer and you keep from losing four cyl's power at the 1-2 shift. It, alone will add 20-30 HP and some more torque too.
You have to decide which chip/tuner to use though or you can be like me and get one from 3 different tuners .
Dan
Dan
I say a chip is good even by itself. Heck I have one sitting here on my desk if you are interested. CHEAP!!!
-Kimball
zbornac@earthlink.net
-Kimball
ok, here's what you want to do. first get a superchip from Mike Troyer (that's what i did), then get a 4way chip from Sal, they are great, and superchips doesn't have a 4-way chip, and that's what i did. then you can get a Diablo chip from Johnny or Bubba, because they are pretty neat and are supposed to come out with a knock sensor program, and that's what i did
chip
Rhino, That was about the best reply to a question I've read in a while, simple to the point and no BS. Take Rhinos advice, educate yourself alittle about what to ask for and then make a few phone calls and see who you would like to do business with. The better known tuners all have there own loyal following for a reason. Good luck, Todd
Re: Re: Diablo Predator
Originally posted by cyntaxx
Isnt the predator going to be a hand-held device like the Hellion? where can i get details about the product?
Pred has advantages and disadvantages.
1 Advantage is you can chip your truck without Ford knowing by flashing the PCM through the OBD-II port. However, you cannot use custom files or dyno tuned files. You will be forced to download the files off diablo's website which arent tweaked to your particular vehicles characteristics.
They are an option for those who dont want to take the chance in voiding their warranty based on PCM tampering. Also have a scan tool and basic mods can be made to the L's computer such as line pressure for the tranny, gear changes to match speedo, timing, etc.
