A/F #'s in the low to mid range , what should i be looking for
I am trying to get an idea of what kinda A/F i should looking for in my lower RPM range. Off idle and up in to the 2500 rpm range? Should i be trying to have a A/F of the same number clear threw the whole RPM range. I have a A/F of 12.0 from around 3200 clear tell 5500 stays right around 12.0. Now i am wondering if that is what kinda A/F i should be trying to keep in the lower RPMs. Any input here guys
Originally posted by speeder
Your air fuel is just fine, at 5500 rpm my air fuel is 11.7, try not to let it get over 12.0 and you will be safe.
Larry.
Larry.
Reason i ask is because at idle its 13.5 or so and as you slowly climb into the RPMS it adds fuel at around 3200 is where i see a 12.0 A/F and stays that untell i shut it down at 5500. I was just wondering if this is something i should be concern about or not. Just try to find out if i should add a point of fuel in the idle to 3200 rpm range is all or is it good at where its at.
I am wondering if i would gain anything if my A/F was 12.0 from off idle clear threw the RPMS or not
