99 lightning questions
The differance is mostly the 01 and 02 have the Larger 90 MM MAF and 373 gears, compared to 80mm and 355 on the 99/00
However 99/00 do seem to have stronger Rods.
With a Fliter-chip-n-pulley, you'll be right there with all of us.
Unfortunatly is seems this year,
you'll need a KB, Whipple, or Juice to keep up with us maniac's
I may have to sell in another yr or so before we resort to Rocket Power
GOOD LUCK
What ever the hell your name is
J/K Throw Down
GOOD LUCK
J/K Throw Down
I can't help you on the price, but there are just a few things that make the 99 and 2000 different than the 2001's and up
355 vs 373 gears
80 vs 90 mm mas air meter.
What most people do is put the larger mass air meter, with a chip tuned for the 90 mm mas air. Then they put a open air filter and a larger lower supercharger pulley. That will make it equal or stronger than a 2001 and up Lightning.
Some people do change the rear end gears, but that is often a later mod, after most of the other bolt on mods are done.
355 vs 373 gears
as far as reliability, its up in the air. I had a buddy with a C5 and his seemed to be in the shop all the time, mostly with tranny issues i think. But at the same time, I'm taking mine into the shop today for the 5th time since I've owned it.
If your buying a used vehicle, its all up in the air. Make sure it hasnt been modded in the past, at least there will be a better chance it hasnt been abused...
