Can I use stock temp for autometer guage?
Hey, I want to use the stock sensor for my autometer guage. Is that possible? I dont want to hack a hose or tap the housing. Can I simply splice into the sending wire on the stock plug? And if so, does anyone know which wire it is? I am trying to keep the stock remp guage functional, so I just want to tap into the stock sending wire if this is possible. Thanx all.
won't work
the sensors are callibrated differently. Trust me.............i looked at every option Reason why I went with the hose (no, it's not hacked).........is because if i decide to get rid of the pod to return to stock, or anything else, it's alot easier and cheaper to replace that hose then screw up the manifold.
Another option i haven't seen you mention i the plug on the driver's side of the block. Temp isn't as accurate hear and if you have an electric fan, this hole is already used.
Like I said in my other post, the project looks rough because i did it at the end of the season and just took the truck out of storage, so i just tapped it up to make it look at bit cleaner for the last trip to the track, but a 1" diaamer piece of wire loom will easly make it look factory and no one will ever know it's there. When's the last time you checked out someone's heater hoses?
dayum!
i took the time to make you a nice little diagram and you must have missed it!!!
https://www.f150online.com/forums/sh...0&pagenumber=1
Like i said i just wrapped tape around it to clean it up again, but i'm gonna put some loom over it. Honestly, it looks worse in the picture cause it's a closeup, but you don't even see it when you look under the hood.
