Here where I live in the summer it gets up to 120, I put the hypertech 160 works much better. I just installed an elec. fan with a toggle switch. Right now its around 80 outside and I can drive my L with the fan off all day with no problems. The temp needle doesnt go above half.
160 degree helps in the L as long as the outside temps are above 54 degrees F. Any lower and it may blow a code. Go for the 170 degree and stay in closed loop mode.
STOCK IS 205-I JUST INSTALLED A 160 FROM HYPERTECH AND IT WAS THE EASIEST MOD I EVER DID,IT RUNS ABOUT 170 NOW,GET RID OF THE STOCK ONE,THE CLUTCH FAN KILLS THE POWER
J
