upper grill install
there are some black plastic push pins under each side of the front shroud. those need to be pried down with a flat tip screwdriver. (put a towel in place to protect the paint)
you will also need to remove the head lights and corners. pull the corners first. there is a small 10mm screw in the engine compartment that gets removed, then the corners come right out. then pull up on the black tabs for the head lights and remove them.
there are some screws that need to be removed behind the lights.
then the front shroud pulls right out.
it isnt as hard as it seems. just take your time and it is a cinch.
good luck...chris
good luck...chris
