Question for Sal
Dale, the main things to know are-
- studs are a must for high boost applications
- check the heads for warpage, they can warp easy with the abuse we put on them
- use the proper torque with whatever fastener you use
I have not seen any block deck issues, the Windsor engine plant does a great job machining these blocks. As for the head gaskets, OEM Ford is still the best. To prove that point, Randy Haywood from True Blue runs stock Ford head gaskets on his Outlaw 5.4 1800hp monster. I have not used the "new" Ford head gaskets on my truck yet, which are the ones for the oil leak issues.
Sal
Thanks for the quick response...I have the studs and the block and heads were both milled and the shop did a nice job on it.
When I pulled the heads off last night, the studs were all tight, nothing shook loose.
My problems stem from hitting the rev limiter....I'm pretty sure of it. Any ideas on that problem?
Dale
Dale
