What's the differences between the 03 Lightning motor and the 03 Cobra motor?
Isn't the cobra motor a dual overhead cam and 32 valve? They both have Eaton blowers and put out about 8 pounds of boost. As far as rods and pistons are they the same? What motor can handle more horse? Why does the intake go towards the drivers side on the Lightning and towards the passanger side on the Cobra? What else is different between the 2 motors?
2003 Cobra motor
2003 Lightning motor
2003 Cobra motor
BAM!!! 2003 Cobra
Type Longitudinally mounted, 90° V-8, cast iron block with aluminum heads, fully counterweighted forged crankshaft
Bore x stroke 90.2 x 90.0mm
Displacement: 4,601cc/280cid
Compression ratio: 8.5:1
Horsepower: 390 hp @ 6,000 rpm
Torque: 390 lb.-ft. @ 3,500 rpm
Specific output : 84.8 horsepower per liter
Redline: 6,500 rpm (fuel shut-off at 6,500 rpm)
Valvetrain: Double overhead camshafts, chain drive to exhaust cams, secondary chains from exhaust to intake cams, roller finger followers with hydraulic lash adjustment, oval-wire beehive shaped valve springs, four valves per cyclinder
Intake valves : 2 per cylinder, 37mm head diameter
Exhaust valves : 2 per cylinder, 30mm head diameter
Fuel system : Sequential electronic fuel injection
Ignition system : Distributorless coil-on-plug
Induction system : Eaton Corporation Generation IV Roots-type supercharger with water-to-air intercooler
Boost pressure: 8.0 psi maximum
Intake manifold : Cast aluminum, tuned equal length runners
Throttle body : 57mm twin bore
Mass-air sensor : 90mm diameter
BAM!!! 2003 Lightning
Type Longitudinally mounted, single overhead cam, 90-degree Triton™ V8, supercharged / intercooled, cast-iron block, aluminum alloy heads, forged steel crankshaft
Bore x stroke 90mm x 105.6mm
Displacement: 5,410cc/330cid
Compression ratio: 8.4:1
Horsepower: 380 hp @ 4,750 rpm
Torque: 450 lb-ft @ 3,250 rpm
Specific output: 70.2 horsepower per liter
Redline: 5,250 rpm (fuel shut-off occurs at 5,400 rpm)
Valvetrain: Single overhead camshafts, chain drive, roller-finger followers with hydraulic lash adjustment, beehive valve springs, two valves per cylinder
Intake valves: One per cylinder, 44.5mm head diameter
Exhaust valves: One per cylinder, 36mm head diameter
Fuel system: Sequential electronic fuel injection, Premium calibration
Induction system: Pressure-charged Eaton Corporation Generation IV Roots-type supercharger, water to air intercooler in "vee"
Supercharger: 8.0 psi pressure
Throttle body: Dual-bore 57mm
Mass-air sensor: 90mm diameter
I'm guessing the intakes on the two are different because the position of the batteries on the cars. All F150's have the battery on the passenger side and all Mustangs have the battery on the drivers side. They would have to redo the mounting for the battery most likely to get the mustang to have a drivers side intake. Plus Saleen and Roush prolly already had kit's to use that style intake. I don't think you can bolt on the cobra blower to our trucks because I've heard it's also "stalled" for use with the manual transmission. Hope that helps...
