Rusty JDM tips....Anyone else?
Old 03-26-2003 | 09:02 AM
78f1hundo's Avatar
So I took the L out this last weekend, thru the new Blinging 20's on and I was off......Big pimp'n
So one of my buddy's wanted to see them so I drove over there for him to check them out. Of course he said they were super nice.
He says to me, "what's up with your rusty exhaust?"
I'm like shut up, because he helped me put it on. So I thought he was joking because he thought I was stupid for spending 600 bucks on just a catback. Well, he was right, there it was. It had rusted wear they weld the two tips togather. Damn.
So I call JDM yesterday, are you ready for this.......
Justin says "just take a wire brush to it."
Are you kidding me! So, I'm pissed....
So, does any one else have this problem? Maybe a fix?
No wire brushes here.........
Old 03-26-2003 | 09:04 AM
SVTDAVE's Avatar
No wire brush here....i use an SOS or BRILLO pad.
Old 03-26-2003 | 09:25 AM
Justin@JDM's Avatar
Banned
78f1hundo,
I don't think it was me you spoke to. I was not on the phones yesterday. Most likely you spoke with either Anthony or Jeremy. If you want to give me a call and ask for me today I can help you out with your tips.
Thanks,
Justin@JDM
Old 03-26-2003 | 09:28 AM
78f1hundo's Avatar
Now that I think about it, I don't know who I talked too.....
It might have been Jeremy. Who knows??????
I will give you a shot out later, I just thought that a wire brush is a little extreme.
By no means am I bashing JDM, you guys have always done a great job for me and my truck!
Old 03-26-2003 | 09:30 AM
Jeremy@JDM's Avatar
The tips are a a polished stainless steel, so they shouldn't rust.
Give us a call at the shop today and ask for Jim or myself, I believe you spoke to Anthony yesterday, so we can get a better idea of what is going on. We'll take care of this for you somehow.
Old 03-26-2003 | 09:31 AM
78f1hundo's Avatar
Old 03-26-2003 | 09:45 AM
RTKILLA's Avatar
if its that bad with rust I would just knock it down with a soft brush first and then take some fine sand paper and sand it up and then buff it back out, but with stainless I can't see that happening. There must be somthing weird with that, is it maybe some rust water run off that settled on the pipe?
Old 03-26-2003 | 10:01 AM
Fast Gator's Avatar
Keep Anthony off the phones and have him filing work orders
Old 03-26-2003 | 10:20 AM
Jeremy@JDM's Avatar
Old 03-26-2003 | 10:22 AM
easterisland's Avatar
I always thought that stainless steel will rust. You must kepp it clean and use some type of wax on it regularly to keep it from rusting.
Old 03-26-2003 | 11:01 AM
Fast Gator's Avatar
depends on the grade of stainless (Its the nickel content)
Old 03-26-2003 | 11:08 AM
blackjack's Avatar
For those with the JDM Stainless Steel Exhaust tips. I cleaned the tips on my truck using the following products/procedure and had NEW looking tips after.
1. Clean the tips with a nylon wheel detail brush with soap and water. You can buy a detail brush at any store that sells automotive cleaning/waxing products.
2. Dry the tips with a towel.
3. Apply Blue Magic Metal Polish with a clean rag or terry cloth towel. Simply follow the directions on the tube. It may take 4 -5 applications. Your tips will look like new.
4. To remove the rust around the welds, apply WD-40 and wip off with a rag. Repeat until rust is gone.
Hope this helps
Old 03-26-2003 | 11:12 AM
78f1hundo's Avatar
That's what I'm talking about
Thanks, blackjack!
Old 03-26-2003 | 11:15 AM
blackjack's Avatar
No problem...good luck
Old 03-26-2003 | 11:16 AM
unclemole's Avatar
Try a product called Corrosion Bloc to remove the rust and prevent further rust. It comes in a tall silver-gray can, expensive but it works 1000 times better than wd-40 or blaster. This product is also used on electronics so it won't harm your tips.
Quick Reply: Rusty JDM tips....Anyone else?
