HELP !!!!!!! She runs like crap!
Check the fuses in the box in the engine compartment. Should be on the driver side IIRC. Look for a blue 15 amp fuse for the HEGO sensors. You'll need to refer to the manual for which one.
I had that fuse blow and it did nearly the same thing you're talking about. You can borrow the fuse for the radio to get you to an autoparts store for a new one if that's it.
Originally posted by Sawzall
Thanks guys.
I just called the dealer. Its going in Monday. Im calling a flat bed to come and get it. I dont think it will make it there on its own. I will keep you posted on what it was.
Thanks guys.
Actually, if you've got some tools and a couple buddies, you can check the pump easily yourself. Just pull the bed off and the access is right there. When you put the bed back on, you can align it too!
