i think my tranny is starting to slip...
...you guys could probably help me out though.
when im on the freeway and i give it some gas, i hear the blower start to wind up, then fall off and then start winding again.
when i get on it from a dead start, as it shifts to second, the blower seems to let off some then starts going again.
also, when i do a u-turn or speed up out of a turn, my engine revs up but my truck doesnt really go anywhere. then it will lock in really hard and start going.
any ideas?
on a lighter note...i went to the track last night to try out the new mods. i ran a new best of 13.43 @ 102 mph. i cant seem to get my 60' under 2.0. track is over 2000' elevation.
thanx for any help...chris
any ideas?
Re: i think my tranny is starting to slip...
any ideas?
any ideas?
sorry to hear this Chris, gotta suck..
Dana
Those symptoms don't sound like a slipping tranny to me. If the trans was slipping, your s/c'r and eng. would spin faster not bog down. If the blower is falling off, this is a slipping belt. That's all that powers the s/c. If the eng. is falling down, how many miles on your fuel filter? How dirty is your air filter?
Dan
Dan
Originally posted by Transhop1
Just for grins check your trans fluid, If its low enough when you turn or accellerate it may be that the pickup is no longer submerged in fluid and causing the pump to cavitate [pull air and not oil] in which case it would disengage.
