JDM heat exchanger help!
So today I installed(finally) the JDM heat exchanger. The couple problems I have are as followed.
1) When I opened the box there were about 5-6 spots wher a bunch of fins were bent down.
2) I removed the front grill and would like to keep it off(I am probably the only one here who likes it without the grill on), anyway, what can I use (screenwise) that would block rocks and stuff from damaging the heat exchanger?
3) Since the L front bumper and HD front bumper differ, my heat exchanger sticks out from the bottom about an inch, what can i use to hide this?? I noticed that it came with 5 holes with plastic push pins in them, what are these for?
Thanks, Jonathan
Thanks, Jonathan
Re: JDM heat exchanger help!
Thanks, Jonathan
Thanks, Jonathan
2. You can leave it open. Ricers do all the time. Just check every once in a while for leaks or bent fins. Note: I do not recommend this but I have seen it done.
3.You could paint the bottom of the Heat exchanger Black to make it less noticeable or you could fab up different upper brackets to raise it up.
The 5 holes are for the rubber piece that comes on the Ls that also attach to the front valence and help the flow of air. I do not know if the Harley has one.
Hope this Helps.
VINNIE
