For those with Hotchkis Leafs
Originally posted by Ayrton
The Roush just uses an unloaded rear spring and some drop coils and that is why you lose you load rating, but is does come with Bilstein shocks for a good price, but it is still not a stiff as the Hotchkis.
Originally posted by RollinLimp2001
Ok so on a ride quality scale of 1 to 10...
5 being a stock setup
Where do these rank
A.) the hotchkis setup with bilsteins
B.) the hotchkis setup with QA1s
Sorry I'm visual so a number scale helps
Where do these rank
G.) Come to think of it, can't really answer this either, since the Hotckis coils are too soft for my taste, I have Ruslow's 1100# coils, and they are still too soft, going to cut them and try to make 1300#ers out of them. So, on a comfort scale, with stock being 5, my truck is about 2. Shooting for 1, though.
I am running the Hotchkis rear leafs as well on my 2000 and the additional spring rate simply over powers the factory shocks. I added a set of Eldebrock IAS shocks to the rear and it rides way better. The Eldebrock shocks really dampened the ride back down and I am really impressed with them.
Hankfan - Is that all you have done to the rear is the hotchkis springs and edelbrock shocks? Looks like yours is a little lower in the rear than what just the hotchkis setup provides.
Anyone else run the IAS shocks? Better or worse than the QA1s?
I know alot of you use the QA1s so I may have just answered my own question.
Adjusting the ***** takes all of 60 seconds for all four. Yesterday at Willow Springs I was on the starting grid and saw the one-minute warning. Just then I realized that I had forgotten to bump them up. Jumped out (with helment on), adjusted all four up 2 clicks, jumped back in, belted up, and was ready to go when we got the green flag. The only thing better than that would be cab-adjustable.
Originally posted by Tim Skelton
It's not even a fair fight. The QA1's are adjustable. No relying on the shock manufacturer's valving choice. And you can bump the shocks way up for road racing or up in the front and down in the rear for weight transfer at the drags.
I run them at 6 on the street
Originally posted by alphadoggy
Would not recommend doing just the rear. If you stiffen just the back end of the truck it will change the balance and result in a potentially dangerous oversteer condition. And, yes, the ride will be a lot stiffer.
As far as the ride quality, it will get noticably stiffer. Depending on the settings of the QA1 in can be good to very bouncy.
So can you adjust the QA1s enough to give you a near stock ride from the hotchkis?
On your scale I'd say the hotchkis kit with QA1's (8 front, 6 rear) would rank about 8 on your scale.
