For those with Hotchkis Leafs
Did it drop your truck a true 2 inches? Comments on handling improvements, ride, etc.?
Also, will I need to change my shocks or will my stock Bilsteins work well with them? (I have a 2002) Anything else recommended to go with the Hotchkis leafs?
Thanks in advance!
Thanks in advance!
I plan on doing Hotchkis coils up front so I will be a 1.5" or so drop correct? Any issues with bumpsteer? Also what are the rates of the Hotchkis coils?
Would I only need new shocks for the rear?
This looks to be more expensive than I thought....
So far I plan on doing:
Front:
Napa cam bolts
Clunk washers
Rear:
Hotchkis Leafs
QA1s (I know there are other aftermarket choices but I like the QA1s)
Am I missing anything else? No one makes a bump steer kit yet correct? How do I address this issue?
Front:
Napa cam bolts
Clunk washers
Rear:
Hotchkis Leafs
Front:
Napa cam bolts
Clunk washers
Rear:
Hotchkis Leafs
Front:
Napa cam bolts
Clunk washers
Rear:
Hotchkis Leafs
960lb Front
300lb Rear
I'm thinking of doing the same thing to my truck. Do the QA1's really help calm the hotchkis leafs down better than the stockers? Cause I heard the hotchkis leafs are pretty stiff on a stock setup...and I don't want to get much worse ride quality than what I already have. Anymore comments on this setup would be appreciated. Thanks
Originally posted by MHMCGILL
So has anyone just installed the rear leafs only? All I want to do is get rid of the rake or at least minimize it. I know shackles would do this but if it is feasible to start with leafs I would do it.
however i dont know if i want to drop coin on a complete setup at once if i have to get new shocks, etc
In order to maximize the potential of the Hotchkis kit you really need to run the QA1 shocks. Hotchkis of course is really designed more for handling than just lowering and I have no complaints about mine, but some don’t care for the ride. However I did drive mine back to back with a stock truck and on the freeway there was little difference IMO. It wasn’t until you start hitting curves that you really see a difference.
You will need new bump stops, but they are cheap and available at any Vato Zone or Pep Boys. There is no bump steer kit for the F-150…. yet.
I don't mind the stiffer ride (I am still half-contemplating the full Roush setup) and am seeking handling improvement as much as I want to see a drop in height.
The only thing I don't want to do is spend too much money on the truck. I wish I could do the leafs now and come back for the QA1s later....but I know it is ideal to do everything at once so the stock bilsteins don't get torn up too much.
That puts a hefty price on just the rear alone...close if not exceeding 500 bucks!! For less than 200 more is the rull Roush setup with shocks, leafs, springs, etc...
So should I do just the rears now, or wait to do it all at once? I'm just tired of my truck sitting so high in the back.
Originally posted by RollinLimp2001
Ok so on a ride quality scale of 1 to 10...
5 being a stock setup
Where do these rank
A.) the hotchkis setup with bilsteins
B.) the hotchkis setup with QA1s
Sorry I'm visual so a number scale helps
Where do these rank
