Boost bypass and KB blower
I was trying to get rid of some of the vacuum lines and solenoids I don't need under the hood. So, I took out the boost bypass solenoid thing and plugged the bottom black vacuum hose and attached the top black hose to the vacuum lead for the actuator on the blower. It seems to be running good. The top black vacuum lines goes to the upper intake plenum and the lower goes to some type of plastic box behind the battery box.
Any comments if this was a bad thing to do or not?
easter
I've had mine set up like that for a long time or at least close to that. I found out I could get the valve to close quicker if I just plugged it into the upper manifold. I drilled and tapped a hole right behind the throttle body and ran a short piece of 7/32 ID rubber hose to the boost bypass valve direct. When you open the throttle the valve closes a bit quicker. One of these days I'm going to drag race it with thte valve unplugged altogether. When you unplug it and play with the throttle it sure seems to rev quicker.
Worth a try
Dale
Worth a try
Dale
