Oil Seperator Question
http://www.nloc.net/forum/showthread...threadid=45611
I got it at www.razorsedgemotorsports.com
That circut is a "PCV" valve and hoses. (Positive crankcase ventilation) The point is to pull crankcase gasses from the highest point (valve cover) and burn them. As well as keeping a steadily designed vaccum on the crankcase.
WOT
WOT
Originally posted by bad00
whats there web address
Dan
Originally posted by easterisland
WOT, Since you seem to know about these systems, if I removed the tube which runs fom the bottom of the lower intake plenum which connects to the pcv system(I guess to draw the excess oil out of the lower intake) would I show more boost than if I was to have the tube connected?
Dan
