truck running bad
truck running bad
i can't give no more than 25%throttle or my exhaust sounds like a harely (bike) and it barely moves, and the truck usually shakes when i do that a bit
i recently changed the fuel filter, the old one was extremely dirty
i also put a in fuel system cleaner
wat could be the problem?
this prob happened after my truck been sitting in the driveway for 5days cause i had an accident at work and severly fracture my arm, first time i could actuallly drive this problem happened
i thought maybe moisture got in the gas cause of the huge temperature drops the past few days (it was like 40's one nite and amlost close to 100 another day)
the sound comes from my exhaust cause i can only hear it out my back window
the plugs are still in the head
and there are no leaks anywhere, i thought maybe changin the fuel filter will fix the problem, it only helped a bit wit the stuttering
My truck dies on me every once in a while and its usually after sitting for a while. I have had it in the shop lots of times but they could find nothing wrong. I also make the mistake of letting the fuel go all the way empty. I heard you should not let the fuel go under 1/4 tank in our trucks.
