plug gaps for Nitrous
I need to know plug gaps. I bought a NOS kit and going to run it dry. below are my mods. I'm going to start out with a 55 shot. Do you need to adjust your gaps the bigger the shot? I don't plan on going over 75, for now anyways. What do you guys recommend?
Thanx
Nathan
Thanx
Nathan
Nate
I still run Denso IT-22's @ .038 - .040
Same as I ran it before installing the Juice
Mine Idles perfect
Runs 8/10th's quicker with Juice than it does without
I also still make all Gasoline runs w/4 and or 6 lbs of Pulley
Juice runs w/ 4 and or 6 lbs
I run it w/low and high timing (Differant Chip Programs)
And each is as consistant and trouble free as the next
Pulls like a Mo Fo the whole way through
Mine Idles perfect
