Built short block and stock heads
when i get out this wheelchair (sometime in july i hope) im gona get the built short block and works 140 prolly from razor edge.
im gona use my heads i got now but was woundering since there is only 4 threads for the spark plug building it up more
has any body done this or have a better idea i dont want a onwanted ram air hood you know
I have the solid inserts and was told once those are in thats it. If you go with the spring type, I was told if something happens down the road that the solids could then be installed. I say this is cause of detonation I almost burned a helicoil too bad. I would go with the spring type if I could. Good luck on your bottom end. Your porting those heads right?
