Brake question with Kenne Bell Blower??
Don
What kind of noise was your Kenne Bell making? I had a built short block put in the same time as my KB and noticed a new noise when I first drove it. Chalked it up to piston slap on the built motor, but upon listening under the hood found out it was coming from the KB. When I put a tighter belt on the KB (changed upper pulley) most of the noise went away. Let me know what you found out on yours.
Mark
Mark
Re: Don
Mark
Mark
It went away as soon as I got over 100 rpms.
Don what is your vacumn at idle? If you don't think its your cams it could be your by pass not functioning properly. Works 140 with out by pass was like 3 inches of vacumn at idle (brake issues) with by pass is about 14 (no problems).
Steve
<Duh... thanks for correction jarmstro
Steve
Re: Re: Don
Originally posted by Don's Bolt
It is hard to describe, but it was sorta like a clunking niose, but only when at idle.
Originally posted by Calightnin
3 lbs of vacumn at
3 lbs of vacumn at
Example:
A perfect vacuum would be one in which the absolute pressure would be zero (in any units).
That would normally occur when the amount of vacuum was 29.92 inches of mercury (meaning that the absolute pressure was 29.92 inches of mercury below the ambient atmospheric pressure).
Just for your information, 29.92 inches of mercury is equivalent to 760 millimeters of mercury or 14.696 pounds per square inch.
Originally posted by Dale-01L
I would be willing to bet that its not from the blower, but from the big cams.
big cams = very little vaccum..
The blower should have nothing to do with it.
-Dale
-Dale
JE
Originally posted by jarmstro
PLEASE vacumn is measured in inches only. 30 inches of vacuum is perfect and cannot be attainable here on earth because it will crush whatever it draws the vacuum on. Outer space is a perfect vacuum. Trust me I dealt with this for many years.
Example:
Example:
wow someone payed attention in skool
