Looking for A/F Data
#46
Re: Re: Re: WHAT WAS YOUR RWHP???
Originally posted by Hilander
These figures are a little low, but some trucks respond much better than others to mods. Yours would probably pick up more than most
I plan on getting a chip, was gonna get one yesterday if they had someone to burn it at the dyno, but the tuner wasnt there.
I guess I'll just get a mail order chip. I need to do some more research on it before I do it to decide which one I get and what my future mods are going to be.
#47
I agree with what others have said, Not only are you guyes A/F ratios whacked but your HP readings are also whacked. I didnt read it but was this a tail pipe sniffer ? I wonder how long it had been since the tip was changed. As for the low readings, Sharpshooter are these corrected or actual numbers ? The only way those numbers make sense are if they were actual, meaning the dyno wasnt taking you altitude or heat into consideration.
#48
If I'm looking at this chart correctly my #'s are actual, but the correction factor is only 1.03. If the numbers on my chart arent corrected then I multiply them by 1.03, that will give me 334 hp instead of the 324.7. I dont know much about these dynos so I might be wrong.
#49
http://www.horsepowerfreaks.com/Show...ategoryCd=O2KI
FJO KWB0240 Red Display
FJO KWB0241 Green Display
Then hit this link for the $50 rebate which applies to the actual wideband sensor.
All you guys need to do is goto a muffler shop and have them weld in an extra 02 bung. If i could do it all over again, i would have installed it on the passenger side before the cats opposed to the drivers side. Makes snaking the cables a hell of a lot easier.
Youre looking at $1000 when said and done. Divide that between 3 or 4 guys, thats chump change.
#51
Originally posted by Sharpshooter
A/F was done with a tail pipe sniffer, no idea about the tip.
#53
Re: Re: Re: Re: WHAT WAS YOUR RWHP???
Thats encouraging, lets hope your right.
#56
Originally posted by cyntaxx
Gator, do you just troll around the boards making stabs at people? I've seen you do a lot of that lately..... Guess the Louisville Hooters isn't cutting it huh?
Open your eyes-grow up-be a man
Any thing you don't understand? See ya soon, bud.......LOL
#57
Originally posted by easterisland
I don't use rear O2 sensors. So I blocked one of the stock holes and installed the wideband O2 into the other. So far it has lasted around 11K miles. I have also ran around 40 gallons of leaded gas through the engine.
