Looking for A/F Data
Guys, Went to the dyno today. I will not post any a/f numbers....but I will say that the 3 trucks that showed up had pretty much the same a/f numbers. Even the stock truck......So I would like to get some info on the a/f readings from any L from stock to modded.
Thanks to all that post a reply
lander i was showing about a 16 AF ratio which has to be off, i would be pinging so bad it wouldnt even be funny, i was told all of you guys ran really lean, and my exhaust is a little longer so i can see it reading even leaner. email me your info or your af graph if you can/want to so we can compare data.
Originally posted by Sharpshooter
Had mine dynoed Today.
Bone Stock.
3000 rpm A/F 15.7 that number decreased evenly until 4300 rpm where it stayed at 12.6 for the reaminder of the run. I had an average of 13.6 for the entire run.
My Trucks power is way down compared to other stock trucks. I dont have a clue why this is.
Bone Stock.
Originally posted by WHITE01XXX
Why not get a decent air/fuel gauge, modified for our trucks.
We did a dyno day and the guys with the MR.GADGET modifed gauges were dead on.
Some guys in my club are doing a two gauge air/fuel for both sides.
That way you now where you are all the time.
Originally posted by Grey03
Do you know why your tailpipes are black and sooted up??
I'll give you a hint......... Its not because you are running pig rich.
DEDICATION
DEDICATION
You know JJ, for someone who claims to be such a tuner and tunes his own truck, explain why you have blown up more Lightnings then the top 3 vendors combined?
Go take your Plasma Booster miracle power maker and stick it in your ***.
I've been to the dyno on numerous occasions to check a/f ratio, as well as my progress. Mine have ranged from dropping off the chart richness at about 4200 rpms, on one tune, to a 12.7 on an old tune with a new mod added to the mix. Most of my runs have fallen into the 11.5 to 12.0 area. Measured at the sidepipe.
