What does it mean...
Originally posted by ShadowLightning
yeah, truck runs fine...in the morning I'll drain the battery again and reinstall the chip...hopefully that works
Good luck...
Originally posted by cyntaxx
Don't need to drain the battery. Just disconnect the negative, wait a couple of minutes, then reconnect. Also, check the contacts of your PCM and make sure they are clean. Make sure the chip is attached and you may want to tap it on the PCM.
Good luck...
Good luck...
