Traction problems, is it my pinion angle?
Well, I want to set up my rear suspension geometry. First off since I went to the Nitto drag radials and added the upper 1 which adds actually 2 due to my lower 5/6 (Old Metco) my 60's suck.
I ran a 12.935 @ 110.32 with a 2.046 60 ft. With that MPH I should be easy in the mid 1.7 (Eventhough that was a freaky MPH, I let the truck do a nice cool down) I'm gunning for the Long tubes this week and doing the converter so the truck should really fly but I need to get it to the pavement.
What should the pinion angle be? Do you have to angle the differential down? What about a preload on my lower Metcos? I have a set of 2 degree wedges from Mr. Gasket. I'm getting some hop off the line. Once I'm on a roll she goes well.
I used to run 12.75 @ 107.5 1.85 60 (Pre upper and Heat exchanger & 3" JLP shackles) with 26" ET streets.
Could the 3" JLP shackles have thrown the angle out of wack???
You just can't drive!
Ideally, the angles between the transmission output shaft and driveshaft, and between the driveshaft and the pinion will be equal and opposite. In other words the extended centerlines of the transmission and rear end should be paralell. A couple of additional degree's snout down should be added to compensate for the pinion rising under launch.
But I told you that already...............
We will fix it this week you ***!
Eric
Eric
Ideally, you dont want to run more than a 4 to 6 inch pinion angle on the street due to the large amount of tension on the leafs will make for a very rough ride and will actually raise the back of your truck...with slicks its a different story..Id run an 8 degree p-angle at the track....but let owheelies get his hands in there, heeeel hook you up, hes a goood man I tell you...
Funny you asked because im going to be checking my pinion angle as well. I think when i had the left rear seal replaced, my pinion angle may have gotten jacked up.
I talked to SAL about this this morning. He said between -3 and -4 is where the pinion angle should be.
I was only pulling a 1.92 60 this week at the track AFTER installing rancho's. Granted, they were on an 8 inch wheel, but that is still a sorry *** 60 for slicks. So, one thing im checking this week is indeed the pinion angle.
Looks like pinion angle will be responsable for at least a case of beer this week...........
Funny you mentioned the seals. Looks like I'm due for that procedure too. When washing the truck I noticed a liitle dripage.
"Looks like you blew a seal."
"Leave my personal life out of it and fix the damn thing!"
seals+maybe 3:73's+plugs+check my own pinion angle=time for a Beermeister
Eric
Eric
http://www.paulshp.com/lightning.htm
Shackle Kit - drops back of truck approximately 2" so truck sits level but more important the pinion angle is increased from 0-2° negative which makes the truck hook a lot better. Poly-bushings included with shackles.
