Part number for Ford HD DOT 4 brake fluid
Much better. It does not absorb moisture as bad as the Ford fluid. You won't boil it with your big brake kit. Besure when you switch that you flush the whole system. Just keep bleeding until you have bright blue fluid at all four wheels. I switched to it when I went with the Stop-Tech big brakes. I am now back to stock on the brakes and the pedal feel is much better that the stock fluid. This is a great all around daily driver/ light open track fluid. There are better track only fluids but they don't work well on the street. To me this was the best of both worlds.
