How much ATF for stock pan?
I just flushed by system yesterday. I have the 4x4 pan, and total refill (Mobile 1) was 17.5 quarts or so (just under 18).
If you remove the stock pan and refill it, it will probably take around 6 quarts (if I recall correctly, the 4x4 pan took around 7 quarts and it's supposed to hold 1 quart more).
Hope that helps.
--Rip
Hope that helps.
--Rip
yep.
I'm not sure if you can mix the RP with the rest, though. I'm kinda **** retentive, so I won't mix 'em. Greg E says you can mix Mobile 1 ATF, but I haven't heard one thing or the other about RP.
Since I bought the Mobile 1, the shop that did the switch only charged me $49 and it took about 15 mins...
--Rip
--Rip
