Kenne Bell with Reflash............
For a small comparision.....I was running 12 lbs Eaton - with no chip and ran a 12.96 in cool weather (about 50-60 degree weather)
But the last few times at the track in the heat (about 82 degrees) I was running 13.3 (12 lbs Eaton - no chip)
Then I added a 75 shot of ZEX on and ran 12.75 @ 107 ( 12 lbs Eaton -no chip). 80 -85 degree temp.
Removed the Zex and installed Kenne Bell @ 16 lbs with no chip (about 80 - 85 degrees) and ran 12.82 @ 107.
Now reflashed with Kenne Bell running 16 lbs with the temp about 92 degrees with only a 45 minute cool down I ran 12.49 @ 110.64
I cant wait for that cool Fall weather to get here....I should be running strong then!! (as long as my rods stay in the block!!)
I will be getting on the Dyno in a few weeks and will let you know the results!!
Originally posted by potac
Nice times.
Does the $3000 for Kenne Bell kit come with everything you need for the install so the only other thing I would need is a chip/reflash?
Thx
Nice times.
Thx
KB pulley chart
3.5" upper and 6# lower = 13.5#
3.25" upper and 6# lower = 15.5#
3" upper and 6# lower = 18#
2.75" upper and 6# lower = 20.5#
2.5" upper and 6# lower = 22.5#
2.5" upper and 8# lower = 24.5#
2.5" upper and 10# lower = 27#
2.5" upper and a 12# lower = 29.5#
6# lower is a 9 inch
8# lower is a 9.5 inch
10# lower is a 10 inch
12# lower is a 10.5 inch
Re: KB pulley chart
Gary Sloan
I am running the 3.25 upper and the 9" lower at the track.
Then I swap out to the 3.5 upper (14lbs) and head back home!
Originally posted by C BROWN
Nice results
Hey; you need to bring that truck down to Pensacola, and show us what some 1/8th mile passes look like KB'ed
BTW: What was your 1/8th on those runs?
Nice results
1/8 mile was 8.03 @ 87 w/ 1.83 60'
