Dyno Numbers In
hmmmm
re read my post
I agree.....something can't be right???? If this is the setup you ran 11.9 on I think you might have broke their dyno
9lbs of addional boost with your mods should put you in the 450hp/ 550ftlbs range minimum. Work those bugs out man, you've got yourself a monster there.
Can you post your dyno sheet???
Re: Damn!
Originally posted by Silver-Y2K-SVT
Not trying to pizz on the parade, but isn't that a tad weak for the mods?
I'm guessing there are folks out there with a chip, pulley, intake, and maybe e-fan pulling those numbers. Just a guess.
Re: Re: Dyno Numbers In
Originally posted by Rob_02Lightning
[B]ROBS COME BACK
Not bad considering I run 6/100ths of a second slower on a stock motor, tranny, suspension, and exhuast with the original fan, water pump, and no use of ice, fans, exchangers, etc...
[B]ROBS COME BACK
Gator's Answer
All that hot air shooting out the drivers side window, Rob02 has got to be getting an extra 100 hp
Pull 3 with Diablo Chip:
Pull 3 A/F
Pull 3 i did not reset the computer like i did in pull's 1 and 2. This also was at normal operating temp (i.e. no cool down).
11.9 was done with race chip (diablo) on race fuel. I did not do a dyno on that because i do not know of anywhere locally that sells 104 unleaded.
Will
Pull 3 A/F
Will
