Dyno Numbers In
pic:
Mods:
Manley Performance Platinum Series Pistons .20 over 8.4:1 Compression
Manley Forged H-beam Connecting rods
ModMax Plasma Moly Ring set
Performance Main Bearings
Performance Rod Bearings
FMS High Volume Oil Pump
ARP Head Studs
ARP Main Studs
Balanced and Blueprinted block
Ported and Polished Heads
Ferra/Modmax 1mm oversized Valves
Upgraded Intercooler
Single Blade Throttle Body
90mm Mass Air Flow Meter
Cobra R Water Pump
Crankcase Filter
3.73 Gears
Intake
Electric Fan
8lb Lower Pulley
Dial-Ur-Boost 1lb Upper Pulley
Boost-Bypass Kit
Long Tube Headers
Twin 255 Fuel Pumps
Magnaflow High Flow Cats
Bassani Catback
Anderson Ford Motorsport Power Pipe
Dual Program Diablo Chip
Hypertech 160 Degree Thermostat
Denso IT24 Plugs
Factory Tech Monster In a Box Transmission
Precision Industries 2600 Stall Torque Converter
Rebuilt Stock Eaton with 4th Generation Graphite Rotor Packs
Polished Stock Blower
List copied from my Show book
Mods:
ARP Head Studs
ARP Main Studs
Cobra R Water Pump
Crankcase Filter
3.73 Gears
Intake
Electric Fan
8lb Lower Pulley
Boost-Bypass Kit
Long Tube Headers
Twin 255 Fuel Pumps
Bassani Catback
Denso IT24 Plugs
Re: Dyno Numbers In
Originally posted by Spanky99L
results:
HP- 414.06
Torque 547.50
11.9 @ 112 Full weight, rich tune
Stock cams and blower
And NO NAWZZZZZZZ (Directed towards Rob_02Lightning)
results:
HP- 414.06
Torque 547.50
Not bad considering I run 6/100ths of a second slower on a stock motor, tranny, suspension, and exhuast with the original fan, water pump, and no use of ice, fans, exchangers, etc...
(Directed towards Spanky99L)
J/K Bro
AWESOME NUMBERS AND I KNOW YOU GOT PLENTY MORE
Now if we can just harness those spikes and send it to the rear tires
Speaking of tires:
I need new ones lol
Still workin on it. Gonna see how far i can go before i slap the KB on
BTW
I did take over the most horsepower and most torque record there. They wern't too happy as to it was a Lexas modification place and a lexas was the previous record holder
And rob, i'm coming to hunt you down!!!!
Cecil in the fall??????
I need new ones lol
BTW
Re: Damn!
Originally posted by Silver-Y2K-SVT
Not trying to pizz on the parade, but isn't that a tad weak for the mods?
I'm guessing there are folks out there with a chip, pulley, intake, and maybe e-fan pulling those numbers. Just a guess.
re read my post
Its still a "work in progress"
meaning working all the bugs out.
all it needs is time
