Sub Help
Sub Help
I wanted to install a MTX truck Box with 2 JL 10'' W3-2's with some kind of amp don't know how big of amp or what name brand that I need. Here is the problem. Do I need a 2 or 4 channel amp and what dose ohm's mean, what's better 2, 4, or 6 ohms. It will be hooked up to the factory radio. Are there any thing else that i might need, like what size RCA/Speaker wire do I need. Better yet is someone willing to write a how too subject to a sub install.
Most amplifiers are only stable to a 4 ohm mono load, so if that is the case with the amp you're looking at ytou would want dual 6 ohm speakers. Monster Cable is not nessecarily the best for car audio. We used to do monster car audio, but instead now keep them just with home audio. I prefer Stinger interconnects personally.
Why the hell would he want dual 6 ohm speakers? With those he can only run 12 or 3 ohms. I hope you hit the wrong key. but anyway.
I personnaly run 2 Memphis ST104D dual 4ohm voive coil subs at 1ohm mono. I am extremely happy with them and would recommend them to anybody. I have recently switched to the MTX box and it has handled my 550 whats per sub fine.
I would either get 2 2ohm single voice coil subs and run at 4ohm by wiring them in series.
-OR-
Get 2 4ohm Dual voice coil (DVC) subs and run them at 1 ohm, or at 4 ohm. These subs will allow for greater versatility in wiring, just as any DVC will allow.
Ideal situation for you would be to get 2 DVC 4ohm subs and then run them at 4 ohm, unless you get a amp that is stable to 1ohm. In that case you might as well run the extra juice.
Just make sure you compare specs and the subs can handle the power you throw at them. Underpowering your subs may actually be more dangerous than overpowering them. Try to get as close to the RMS ratings on the subs as possible.
If I can be of any further help or if you need any sort of clarification, please contact me.
-Kimball
-OR-
-Kimball
2 2ohm speakers in parallel would yield 1 ohm not the 4 ohms you stated. I think you meant in series. I hope you hit the wrong key. But anyway...
How are you running two 4 ohm speakers at 1 ohm ?
You dont want 2 6 ohm speakers. Hell I dont even know if anyone makes a 6 ohm speaker ? ? Just get a good amp and some 4 ohm woofers and you will be golden. Depending on how much bass you need/want, you could always try something like the Infinity Basslink powered sub. The Basslink has speaker level inputs too. Good Luck
Oh yeah, how exactly is the root mean square of the woofers measured ? I think you guys are refering to how many watts of power the woofers are rated to handle.
thanks for correcting me on that series/parallel mix up. Fixed it in the last post.
The subs I am running are dual voice coil 4 ohm, I wire each sub individually in parallel, then connect the two subs together in parallel. resulting in 1 ohm.
-Kimball
-Kimball
