3/4 Drop Issues Kits Never Mention
Here are some issues you will have to deal with if you ever decide to install a 3/4 drop. Hope it helps out in the future.
Had to cut a piece of black metal to secure E-brake bracket to bolt that is ontop of differential. No more noise from bracket bouncing around.
A bracket had to be fabricated to connect the E-Brake lines. With the drop you will need like 2" of additional space on the stock bracket. Thanks to Flatsman he made one for me and it worked perfectly.
Interesting, I guess I will check my lines out now. Any news on your repairs? Also, if the offer for use of the bra for this friday is still good let me know so I can pick it up from you before then. I have some LEDs for you to give to Jon as well, the ones he bought are actually pretty bright. The resistor kinda kills them some but its the only way to keep it safe on 12V...I snagged some "spares" for him incase he loses some or they burn out.
Truck went to Walker Ford (what a bunch of retards), they fixed my Intercooler but never touched the rest of the truck. My intercooler had a wire that had completed burned up and a bad sensor.
Brought truck to Jon's, next day the AC Compressor siezed causing the accessory belt to smoke. So it was towed this morning back to a local mechanic that is really good with electrical problems.
The only good things is my Dad let me borrow his Mark 8 until my truck is running right, so no car rental is needed. Good things I Love my truck and don't wanna get ride of it.
It's a smaller version of George's piece he has on the front of his truck.
It put some good marks on my hood so I took it off.
It attaches with screws and clips, if I where you, I would just drive down and chance it. Cause you might have a few scratches in your paint with the deflector installed by the time you get back.
