Compression...
Compression...
Im out taking compression tests on all my cylinders. What im doing is cranking it, and once it starts shutting it down. Im getting around 150ish PSI in #5 #6. If I let the truck run and release the pressure while running, then let it rebuild in those it only gets up to about 70 PSI. On #7 and #8 when I crank it up it gets to about 120 PSI, but when I release and let it rebuild they too get to around 70 PSI. What should these numbers be at?
-Mike
-Mike
Originally posted by Don's Bolt
I don't know the right procedure for our engines, but if you disconect the coil pac wires, pull all 8 plugs, and pull the fuel pump fuse it would allow you to crank the engine without it starting.
-Mike
Pull out all your coilpacks and plugs, you dont want to fire the motor....put compression tester in one plug hole and turn engine over 5 times (cycle it 5 times) You can count 1 every time starter burps....do the exact same way for all cyclinders....your numbers should be around 150psi for your motor....and the rule of thumb is no variance of more than 15% between cylinders...ex. if your lowest cylinder is 135 psi than your highest cant be more than 155 psi.....if so you got a problem..
pull 8 plugs.....
pull 8 plugs.....
Originally posted by promodlightning
Pull all plugs......... ,
Originally posted by Ak.Silver2K
Pull the plugs...
Pull the plugs...
The worse 3 words a L owner can hear
I can pull the Motor of a BB Chevelle
faster than doing our plugs
Good luck Mike, this sucks..........
