Is something missing from my upper pulley?
I've been struggling with an upper pulley swap for the past few days. I've readthat you need to remove the stock bolt from the pulley then remove the pulley. I have also read that there may also be a washer on there and that it helps in puting the new pulley back on? Well I have neither a bolt or a washer on my stock setup. I have an 03 and was wondering did they change something or am I just misunderstnading the whole procedure? Do you guys have a bolt or screw or somekind in your stock upper pulleys?
Yes there are threads under that plastic cap. I have it all figured out now. I ordered the kit from JLP but never got instructions or the little packet of hardware that are supposed to come with it. I didn't realize anything was missing from the kit though until I talked to JLP today. I was confused because I thought they had sent everything I needed and that I was supposed to use stock parts from my truck that I didn't have. He explained it all to me, and the pieces I need will be here shortly. Real nice guy and great customer service.
