cant find rear gear filler hole
Originally posted by JeffsLightning
The fill plug is on the driverside about 1/2 to 2/3 up on the differential. You use a 3/8" extension on a ratchet to remove it. You fill the carrier up until it is just slightly below the hole. Some people pull the abs sensor on top of the carrier and fill it that way...
