went to track with new mods and happy
went to the track again today "only my second time" and two weeks agao i ran a 8.74 at 81 with horrible 60' times "2.1's"
well i han john install a 90mm mass air and datalog the truck and today i ran the f1's at 32psi and still had a 2.1 60' and ran a 8.506
at 84mph i was pretty happy here are my mods
00 "L"
dialblo chip tued by JLP and datalogged 11.4 afr
JLP air box
5lb lower
single blade TB
90mm mas air
factory tech valve body
2400 stall converter
no hitch or spair tire 3.55 gears
00 "L"
JLP air box
5lb lower
single blade TB
90mm mas air
Nice ST.ELMO'SFIRE
Now lower those suckers to AT LEAST 25 psi.
MAYBE LOWER (I never raced it w/higher than 25 psi)
I cut 1.8 -1.9 each and every time I raced with f-1's @ 25psi
except (1) 2.0 on a crappy un-prepped track
Remember,
Every tenth you loose on your 60, should net you
2/10th's better ET
You did good with the new Mods, nice improvement
Remember,
2/10th's better ET
thanks rob, but i must give the credit to two people
Gregg Evans, for rebuilding the trany for next to nothing
and John Wiker of JLP, for his parts, and for taking the time to datalog the truck and get it tunned up for almost free
these two guys are some of the most humble, respectable people i have ever met, and i thank them!
my truck may not be the fastest by a long shot but for a stock block and the boltons i have it shure does run pretty darn good.
oh btw the track i run at is uphill i probably rises 15-18 feet over 660" does this matter?
Great job Aaron! Your truck was definitely haulin' yesterday. I must say that the highlight of the day was driving to the track 'motorcade' style with Mike's 2000L, Russel's racing Mustang 5.0 LX and Dave's Saleen 281. I saw a lot of heads turning as we drove past.
I was pretty happy with my times as well, as my L is 'stock' and it was also my 2nd time at the track. Like you I ran my rear tires at street psi (32), but I left everything on my truck from the spare tire, tow hitch and tonneau cover.
I improved my reaction time, 60' time and even in the 80 degree heat matched my 1/8 mile time from earlier this year with my time of 9.137 @78.1 mph.
Maybe on my next trip to the track in September, the temps will be a bit cooler and I'll be in the 8.9s range.
Thanks for all of the advice you gave me at the track yesterday. It definitely helped me to hook up off the line and have consistent runs all day!
