Magnum Powers & JDM!
#61
Originally posted by webmaster
webmaster note: typical immature, anti-JDM bull**** that needlessly drives positive threads into the toilet removed from this point forward...
public from any honest answers, right? There was nothing
anti-JDM about either of those questions. Just wanted to know
the truth.
#62
Originally posted by SVT_KY
That would be typical holier than thou moderator protecting the
the truth.
the truth.
MORE anti-JDM crap removed from an otherwise positive thread. Any other attempts to drive this in the toilet will result in bannings. I am so sick of this childishness. It will end here.
#63
Originally posted by RiddlerGT
Suavy said he is running his Magnum Powers/ JDM tuned truck this weekend. so finnaly will have real track numbers to go with those dynos! Can't wait to see those real world timeslips.
#64
I would love to give you those numbers!
I went to the track last weekend and even put my big pulley on using my every day driver setting. However, I blew my head gasket going into 3rd gear. All the boost lifted my head and put coolant in my combustion chamber. This blew the top of my expansion tank. So now I'm down to replace my head gasket and a front cover that I broke removing the dampner.
It sounded great went through 1st good with no detenation, then 2nd fine, going into 3rd I went to wide open throttle I heard a pop and then a water fall of coolant covered my windshield. I got of the track and had it towed home. One other thing the heads were torqued to 70 ft. lb and I found out later they should have been at least 75 with my set up.
Suavy
Suavy
#65
I hope the blower turns out to be as good as it sounds but that Muscle Mustang truck has stolen my trucks name. Mine was named "The Fridge" years ago. That ain't right and that's all I got to say bout' that!
#68
I had the old gaskets and my head lifted on the dyno. I originally torqued to 75. I took off the valve covers and retorqued to 95 ft/lbs. I drove like that for a couple of months. The heads would only lift sometimes at real high boost. I changed to the new head gaskets this last time and torqued to 85 and haven't had any problems. I did use moly lube.
Some people have said that my torque wrench is crap because it is a craftsman brand, but I think it is correct. It is only a couple of years old and I don't throw it around much or use it as a breaker bar.
Use this info at your own risk. Most people on here think I'm crazy. I'm definately not a mechanic.
#70
If you have had you block honed with deck plates you should torque the studs to the same foot pounds.
#71
Ayrton,
So your saying I should have torqued the deck plates to 80 lb when they block was honed? I don't think that happened. Are you a mechanic? Not questioning your abilities I just want to make sure this is first hand info cuz I'm gonna freshen my engine up again while its down.
Thanks for the info.
Suavy
Suavy
#72
Originally posted by Suavy
Ayrton,
Suavy
Ayrton,
Suavy
#73
Have the shop machine the block with the thickest torque plates possible (thin plates won't simulate the stiffness of the head), and install the head gaskets and studs you'll be using (torqed correctly). As an added measure, install the mains with the main studs you'll be using to help accurately distort the block.
If you wanna get tricky, some of the really high end race shops can pass coolant through the block, heated to operating temp. The temp of the block will affect the block distorion. Chances are you'll have to skip this step, but if you want total precision its the only way to fly. Its the little details that add up in the end.
#75
rscoleman,
Thanks for your help also makes sence to me. I wasn't there when they machined it. The head gasket issue was kind of a good thing cuz I want to see how the engine was wearing in any ways.
I am not going to let them build it just freshen it up. The repair bay technicians at my plant said they want to do it for me no charge. They even said just bring it to work and they'd build it in the parking lot!
I work For Ford at Romeo Engine Plt. where the Terminator and GT-40 engine are made.
