Ticking noise...could this be the solution???
I have developed a ticking noise when I put the truck in gear. It's a rather fast tick ("rattle") but not there when at an idle and in park. Ony ticking when I'm at idle and in gear.
Could it be the IAC valve? I have read some old posts that these are the symptoms when it goes bad? Should I clean it or just buy a new one?
No, I changed the plugs twice in the past week. No plug problems here. I just cleaned the IAC on my lunch break and the tick is still there. I sounds like maybe it's coming from driver side engine bay? I had a loose line going into the bottom of the air intake sleeve and it had oil all over it. I plugged it back in and still the same tick is there. I'll pull the sleeve this week and clean the oil out of it. Maybe I should pull the Throttle Body too? Is there a gasket that has to be installed with the throttle body? Anyone think of anything that engages in the engine bay on the drivers side that would cause a ticking if it was going bad?
Are you sure it's not just the fuel injectors, as they will make a ticking sound. Sometimes we look to hard for a problem that's not there, but it's always good to be cautious until you can verify what the sound is. It's hard for somebody on a forum to diagnose a sound for you as we aren't hearing it. Maybe you can check out somebody elses motor and see if it is making the same sound as yours. Hopefully it's just the injectors and everything is well.
