performance problems
could anybody please tell my why my truck only made 11hp and 42ft/lbs more than it did stock with these mods? 9" crank pulley diablo sport chip and mac cold air kit . I took it to the track and only ran .1 and a half a mile per hour more than stock. stock was 8.92@79.54mph and modded was 8.83@80.11mph. any help would be GREATLY appreciated
Originally posted by LIGHTNINROD
We need more info: Year of truck, plugs, a/f numbers, timing numbers, 60' times, maintenance(fuel filter change--how many miles?), and most important, i.e., what were the weather differences between the two 1/8 mile passes.
Dan
Dan
Listen to Dan, he knows much ......JR
2003, 11.6-11.7a/f ratio from 3500 to 5200rpm's,stock plugs,both runs were done in evening 75 degree weather. 60-foot times were similar 2.05-2.15, although with mods truck did spin a little more coming off the line. my truck peaked out at 322hp/380ftlb stock and 333hp/420ftlb w/mods same dyno , stockw/1300miles,modded w/4700miles . it gained an avg of 30hp/40ftlb from 3500 to 4500 ,then kept getting closer to stock hp and tq up to 5200 5200=322.1hp/327ftlb stock vs 5200=323.9hp/332ftlb w/mods . i have ngk tr-6s ordered. thanks for the help. also could it be my chip if so could i run stock comp. if i send my chip back for reprogramming with out having to worry about detonation?
