Crank pulley support bracket/cage???
Hey everyone!!!
I was curious if you guys are running the crank pulleys without the support bracket? I noticed that the model I installed came without the bracket and it made me worry about the long term effects on the bearings etc. What do you guys think? Is there enough pressure on the crank pulley to worry? Thanks!
Here is a pic of a cheap cageless pulley.
I used to have an expensive caged pulley setup on my truck. I had to remove it once and it got tore up. Lucky the vendor supplied me with a new center hub piece or I would have been SOL. BTW, it was the new design not the old one. Yes I did use anti seize.
Don't use crack and don't use an aftermarket caged pulley system.
close up of caged pulley system w/o pulley
First attempt at removal
Second attempt at removal
Finally got it off
My engine was on the stand when I did this. I could only imagine if it was still in the truck.
What happens when your accessory belt breaks? I'm guessing you have to have it towed to a dealer and let them have their way with it for a few hours. When they finally decide to cut the damn thing off are you going to wait a week for them to order a stock one or will you carry a spare with you? I would recommend a spare. Since it isn't the cheap way to go you'll be happy. I recommend maybe getting a boost bypass kit while you are spending money, I hear they only cost around $20 now.
Finally got it off
For anyone who is interested, I have an item for sale that works great with the boost bypass kit offered by many on ebay and the internet. It is a high volume blinker pump. Moves the fluid at a much higher rate, reducing drain on the battery, and thus making less drag on the alternator. I also have a fuel molecule aligner for sale.
I've run 2 cageless pulleys on my 01 since it was new - no problems. There must be hundreds of Lightnings out there running cageless - and I've nevr heard of any short term or long term problems. Maybe it's too soon to tell though - but considering how much easier it is to changr pulleys with cageless compared to caged - doesnt appear to be any advantage to the caged one. Let alone what happens if your "inner" serpentine belt (alternator, water pump, etc)breaks with the cages on.
are you sure? Honestly I haven't looked at the lower pully on the cobra but in the shop manual it shows a support?
Was hoping it didn't have one as I too am concerned about going with a cageless or not.
BTW does anyone know where to buy one from in Canada and/or which vendors ship to Canada? (either type, prefere interchangable 2/4#)
Originally posted by 01Lightning
Many will disagree, but I believe the cage will help extend the life of the main bearings. Why do you think Ford designed it that way? That's why I will never run a cheap cageless pulley. Just my .02
one that some have had problems with. The part was prolly
OVERENGINEERED, just like the PCV valves that flow both ways.
There is always a reason for everything, you know ....
