Go fast packages.
I just looked at your profile and see you have a 2003, so I wouldn't go with that package. Fisrst off you don't need a C&L 95 mm Mass air. Also I am not a big fan or the iridium plugs.
I don't know a bunch about RPM outlet, but what I heard wasn't to good.
I would talk to
JDM
JLP
PSP
or REM
These guys deal with Lightnings all day and know the trucks much better than RPM outlet.
I would recomend a
chip
filter
6# lower pulley
New belt
NGK TR6 plugs
thermostat
with the money you save on the throttle body, inlet pipe, and mass air, get a electric fan and cobra water pump.
I would talk to
JDM
JLP
PSP
or REM
I would recomend a
chip
filter
6# lower pulley
New belt
NGK TR6 plugs
thermostat
So the single blade tb is not a good go? Are the stock tb on a 2003 higher flow? I have been terrified so to speak about chipping the truck. I have heard aftermarket chips will leave a lockout code in the computer, and the dealer will void the warrantee. I have also heard about people having to thoroughly clean the prongs of the chip to get it to work. If I go with a chip, do I need a flip chip or a single program chip? I wanna run fast all the time, not just occasionally, so I was thinking that a flip chip would be more of a bother than a good thing. Also, IF I decide to get the chip, pulley, and plugs, what cold air set-up is actually a good deal? I know these are alot of questions, but I wanna get my ducks in a row before I start knocking them down.
Thanks again.
Thanks again.
The throttle bodies do help, but as far as bang fot the buck, they give you the least HP for the money. The throttle body would be one of the last mods I would do.
How are the winters where you live, how cold does it get and do you drive it when it is real cold out??
When it gets cold out the air in denser, which makes the truck leaner. Also the computer adds timing when it is cold. These can be a dangerous combo in real cold air. What you might want in a chip, is a aggressive street chip and a cold weather(winter program) that takes timing out, and richens the fuel mixture when it is real cold out.
I would get a flip chip, it just gives you more options.
All the big three, four use the same basic S&B filter so they are all about the same.
Maybe some of the LFP reflash crowd will speak up also. It would be nice to hear how this is working out over time. If they do well this winter, I'd consider it...
If you go the chip route, I would definitely get the flip chip. The fact that the temp can drop below freezing is enough to make me want a cold weather program.
You could also wait on the Predator to arrive which offers a lot more flexibility and warranty protection, but you may grow old and die before it actually ships.
I don't recommend going over the 4# pulley, but that's me. Too risky and too much inefficiency in the Eaton..
Check out the cold air filter kits from JLP and PSP.
My $0.02.
--Rip
My $0.02.
--Rip
