How much boost??????2003 lightning
How much extra boost will 2.80 reichard upper supercharger ultra pulley create with a 6# lower i am running a 6# lower at this time going to add 2.80 reichard i understand not much difference between a 2.80 and 2.85 running about 14# total boost now mabey 15# at most other mods on my 2003 lightning single blade throttle body cold air k&n filter diablo delta sport chip thanks for your replys/
http://www.msu.edu/~nawrock3/BlowerRPM.xls
plug in your pulley sze in the last column (where it tells you to) and this will caluculate everything and more about pulley size and effect on power and Blower RPM
27.27% RPM over stock
29.9 optomistic PSI absolute
14.9 Optomistic PSI GUAGE
6.4 PSI over stock
4.4 (best guess PSI over stock)
46 lbs added blower drag
65 ft/trq over stock
24 hp over stock
at RPM/ blower speed RPM
5000/16071
5200/ 16714
5500/17679
5700/18321
6000/ 1928614.9 Optomistic PSI GUAGE
6.4 PSI over stock
24 hp over stock
5000/16071
5200/ 16714
5500/17679
5700/18321
I have a JLP 4# lower and a 2.80 upper. I make about 14-15 pounds of boost. The other night it was like 30 degrees out. I got the best seat in the pants ever. I made 16 pounds for the first time on the street program. I am afraid to push it anymore with this cold weather. I would love to put some racing fuel in there, flip the chip to race, and let er rip down the track. But I don't have the *****... But my 4# lower alone made like 12-13 pounds. Then I added the 2.80 and I am right around 14-15#'s.
Will be adding boost gauge etc/
will be adding boost gauge and transmission heat and oil temp gauge later on using gauge pods on left post should have already done so lightning only has 2200 miles on it. it is going to be fast has all the makings of of a good lightning it was bought new in june
