Magnum Power Displacement?
Originally posted by Suavy
As I have stated before I am just a test mule for MP Jim is the Main distributor for them.
I was asked by MP not to give out any info and if anyone needed any info to direct them to JDM.
Sorry Amigo.
Suavy
Sorry Amigo.
Suavy
Bad as L
I'm not sure but I don't think I ever heard of a stock Eaton putting out as much boost as I got out of the MP.
I am finishing my engine by this weekend (Again) and hope to take it to JDM for my race tune we could not tune it last time cuz my stock fuel system wouldn't keep up. We shut it down at 3300 rpm. do to a dangerous lean condition. We did however make 24 lb of boost at that RPM. I am set up to make 26 lb. of boost now.
I put the full 26 lb to it on Laborday weekend and lifted my heads and blew both gaskets.
People said, "that thing sounded like a friggen jet taking off!"
I hear JDM has a truck that ran the MP blower that has now ran 10's.
suavy
suavy
Originally posted by Bad as L
Well....since the MP uses stock Eaton rotor packs, my guess is the MP is right at 112 cu. in. displacement. Is that what you wanted to know ?
Since it uses the M112 rotors then it has to displace that much volume. Dale
Odin
I beleive that the volume is calculated on one full revolution of the rotors. It will displace 112 cu in. You could cut the whole top out of an eaton case and it would still make boost, just not very efficiently. Just because the rotors are exposed does not mean the blower wont "displace" X amount of air.
The stock L eaton has a small portion of the rotors exposed to the inlet. That doesn't make it easy on incoming air, but I'm pretty sure it doesn't make it a 90 cu in blower.
Sauvy
Make no mistake bud.....I believe you when you say you made 26lbs of boost and no I don't think a stock eaton would do that.
The changes that MP has made to the case are subtle but very meaningful. Besides you were spinning the blower with an 11.5" lower and I believe a 2.7" upper, is this correct ?? And the high boost was recorded at less than 4000 rpm before the engine had a fit and shut off.......if I have my facts straight here, then yes I believe you.
When I ran a ported eaton last year, I ran a 9" lower and a 2.8" upper and it made 15 lbs right off and then would fall back to 14lbs.
Dale
Sauvy
Dale
